TwinTurbo.NET: Nissan 300ZX forum - Well, when you put the PP on, it has to be sucked down with
Audioquest
on August 13, 2008 at 9:14 PM
Re: When you adjust the rod, only turn it up enough so
posted by JSD-ZX
on August 13, 2008 at 05:52 PM
the bolts, that's what gives it the clamping force, just like when the pedal is up. The disc really can't go on backwards either. Is your TO bearing lever straight? Even a little bent will result in not as much release
Clutch Issue remains, different problems!!!
JSD-ZX
22:01:56 08/12/08
The way you describe being able to go into gears when it is
5280Z_nightstalker
00:53:59 08/13/08
It can only be one of 3 things:
Audioquest
08:51:51 08/13/08
Re: It can only be one of 3 things:
JSD-ZX
10:29:47 08/13/08
Audioquest
11:06:48 08/13/08
JSD-ZX
17:52:52 08/13/08
Well, when you put the PP on, it has to be sucked down with -
Audioquest
21:14:25 08/13/08
Re: Well, when you put the PP on, it has to be sucked down w
JSD-ZX
04:29:07 08/14/08
Only torque the bolts to 30 lbs MAX or the inserts will
Audioquest
07:54:32 08/14/08
Re: Only torque the bolts to 30 lbs MAX or the inserts will
JSD-ZX
09:55:11 08/14/08
